🎉 Introducing HomeKit Native Firmware for the GDO blaQ!
I have been using a much newer branch off of the konnected-io branch on GitHub. The version there has fixed many of the issues on the main branch. The latest revision has all of the features functioning reliably. The author on the branch is very responsive to issues which has frustrated me with the lack of konnected efforts.
Do you have a link to the branch you’ve been using and how to update to it?
I created the branch that David is referencing. I’ve made a few updates since David helped me test. It also has the option to fallback to a previous firmware version. You can go to my web installer at https://espweb.terazone.com/ and my github branch is at GitHub - atnorman-us/gdo-blaq-homekit: A HomeKit-native firmware for Konnected GDO blaQ · GitHub
I installed two GDO Blaqs and flashed both with the Homekit Native Firmware. Ubiquiti Network with 5 Wireless Access Points. For hte first week or two all was ok but then these started dropping off the network at random intervals. I tried locking them both to the closest access Point and both immediately went offline. At this point these have become unreliable to the point where I cant use them.
Update - I did manage to lock them to my “best” Wireless Access Point and they have been stable regarding network access since then. The drop outs seem to be correlated with the GDO Blaqs roaming between Access Points.
Another problem I have seen consistently is that if my network goes down for some reason and then recovers, the GDO Blaqs go offline and remain offline until I power cycle them (e.g., move cars, climb up on ladder, unplug and replug). Once re-powered they immediately reconnect. I conclude there is no automatic recovery for loss of network connection. This is a fairly significant limitation.
Since then I have encountered other issues. I moved a set of home automation devices to a dedicated IoT network that runs only 2.4 GHz WiFi. That process for the GDO Blaqs was fairly involved though not particularly difficult:
  1. De-installed them from my garage
  2. Re-flashed the Apple Homekit Firmware
  3. Reset WiFi SSID and password to point them at my IoT VLAN
  4. Re-installed them in the garage
My setup provides multiple means for opening or closing the Garage Doors:
  1. Apple Home controls to open/close via the GDO Blaqs
  2. Dedicated open/close buttons on the wall that are routed thru the GDO Blaqs
  3. In car programmed buttons to open/close (this control thread bypasses the GDO Blaqs)
The garage door open/closed status in Apple Home frequently shows errors (e.g. showing closed when they are open, etc). In particular, if I use my dedicated wall mounted open/close controls, my iPhone receives and displays a notification that the garage door was opened or closed but the Apple Home status does not get correctly updated.
This new behavior is correlated with the move of my Home Automation devices to my dedicated 2.4 GHz IoT network. Prior to the move to my IoT VLAN, I did not observe issues with incorrect garage door status - this is a new development since that network changes.
It appears that some open/closed updates generated by the GDO Blaqs are not reaching the Apple Home application. This could be due to a variety of circumstances including problems with the VLAN tagging for those updates.
More detail from structured testing …
I have two MyQ Garage Door Openers and each has a GDO Blaq installed, each has a wall mounted open/close button. GDO Blaqs are running Apple Homekit Native firmware.
Ubiquiti network with an IoT VLAN that supports 2.4 GHz WiFi only. All Home Automation devices are on the IoT VLAN - GDO Blaqs, thermostats, Lutron Caseta Hub, Apple TV, Apple Homepod.
The Garage Door Openers manage the open/closed state of their respective garage doors. In addition, each has a built in light that is automatically turned on whenever there is a control event for that garage door. Each light remains on for 2-3 minutes after any control event for its associated garage door, then automatically turns off.
If I open/close a garage door using my iPhone and the Apple Home controls, the open/closed state of the door and the on/off state of the associated light get correctly reported on Apple Home.
If I open/close a garage door using the wall mounted buttons, the open/closed state of the door does not get updated, but the on/off state of the light is correctly updated.
Specifically - if i start with a closed garage door and open it using the wall mounted buttons - Apple Home continues to show the door to be closed. Likewise if I start with an open garage door and close it using the wall mounted buttons, Apple Home continues to show the door to be open.
In both preceding cases using the wall mounted buttons - the on/off status for the built in light is correctly updated to on whenever there is any control event for the respective garage door. If I wait for 2-3 minutes after the control event, the light times out and shuts off. Shortly thereafter, Apple Home’s on/off status for the light gets correctly updated to off.
What firmware version are you using?
An excellent question …
I dont seem to have any way to actually determine this. No firmware version is reported under the Accessory Settings in Apple Home and my Konnected App cannot locate my GDO Blaqs on my network.
My Ubiquiti console sees both GDO Blaqs on my IoT network but doesnt report their firmware level.
I navigated to support.konnected.io and flashed them with the version that comes up there.
I think Ive seen that you have made changes to the firmware in the GitHub directory and suspect there is a more recent version.
I havent worked directly with GitHub before but would be willing to give it a try.
I went to the web installer at terazone.com linked in your post above, moved my main computer over to my IoT network (where the GDO Blags are), and tried accessing them via my IoT network. In all cases I got a “This site cant be reached (‘ERR_ADDRESS_UNREACHABLE’)” response.
@Aaron_Norman Thank you again for working on this and improving the Homekit firmware for the blaQ. Looks like you had been working on this for quite some time already. It’s only recently been on my radar.
I think we chatted over email a couple weeks ago and I promised that I would take a look into your fork and the direction you’ve been taking the Homekit firmware. Admittedly, we have kinda put this firmware on the back burner for a while, but it’s definitely due for a revisit.
My only gripe though is why no pull requests?
I think it is confusing and a little sketch for end users to have to go to an unknown 3rd-party site to get all the improvements you’ve been working on. Much better would be if we could work together to achieve the common goal. I would strongly encourage you to open PRs to our “official” repo so we can make the Homekit firmware part of our supported offering. This way we can collab on testing, distribution, documentation and support – and you can truly be part of the Konnected community rather than just working off to the side.
I cannot disagree with the gripe here …
Google provides some significant warnings when queried about the legitimacy of esphome.terazone.com.
That being said - my GDO Blaq devices aren’t working as advertised for the following cases:
Case 1
Initial conditions: Garage door is closed and its built-in light is off
Apple Home shows the garage door closed and light off
When i use the wall mounted buttons in my garage to open my garage door: 1) the garage door opens and, 2) the built-in light on the Garage Door opener turns on.
Apple Home now shows:
  1. A notification that my garage door has been opened
  2. The light icon for my garage door opener show that the light is now on
  3. The garage door icon continues to display door closed
Case 2
Initial conditions: Garage door is open and the built-in light is off
Apple Home shows the garage door open and light off
If I use the wall mounted button to close my garage door: 1) the garage door closes, and 2) the built-in light on the Garage Door opener turns on.
On Apple Home now shows:
  1. The light icon for my garage door opener show that the light is now on
  2. The garage door icon continues to display door open
Excluding Apple Home - I have three ways to open or close my garage doors: 1) via the wall mounted buttons, 2) via programmed in-car buttons, 3) via a Garage Door opener remote control. I didnt add GDO Blaqs because I needed another way to open or close them.
I added the GDO Blaqs because I dont want to have to go look each night to verify that the doors are actually closed. So the two cases above are problematic for me.
If Aaron’s release does in fact resolve these issues then I’m 100% in favor of getting these fixes into the product that konnected supports. I cannot determine whether these fixes resolve the cases above, but if they do, I’d like to have them. But along with the fixes I’d like to have the assurance that comes along with an officially supported Konnected product.
I would encourage Konnected to take this firmware off the back burner if that is possible. I chose GDO Blaq because it looked like the best product out in the market for my problem. I’m more than willing to help make sure it is.
Thank you for the feedback @Scott_Landriau.
The core capability of detecting if the garage is open or closed is 100% supported by our underlying gdolib library, which all of the firmware variants use, so if it’s not working in the HomeKit firmware then it’s sounds like a HomeKit layer issue.
I will make it a priority to revisit this Homekit firmware as soon as I can.
Thanks Nate …
A possible hint - I have a Ubiquiti network that provides a default network and I’ve configured several VLANs. I initially installed the GDO Blaqs on my default network and they were working reliably to status the garage door and the built-in light.
As part of my phased network implementation, I migrated all of my IoT devices to a VLAN that runs 2.4 GHz WiFi only. As a result of that change, the garage door statusing now exhibits the problems I reported.
It could be related to improper VLAN tagging of some status updates. For example, the status of the built-in light gets correctly communicated to Homekit but the open/closed state of the door isnt being updated correctly.
I suspect that if a device assigned to a VLAN originates a message with an incorrect VLAN tag, that frame gets dropped immediately by the network.
If it’s a VLAN issue, then sorry can’t help there. Not your IT guy :wink:
it’s espweb, not esphome. So far all my replies look to be quarantined.
My email reply did not make it as a reply. I’m happy to submit PR’s. I’m submitting some initial PRs for gdolib. If they get approved, then I need to rework my gdolib baseline and I can submit the rest of them for gdoblaq.
Sorry my typo …
I’m curious whether the fixes you have made are likely to resolve the problem Ive reported.
This morning I walked through a variety of network and VLAN settings to verify that the network isnt blocking messages, I’ve rebooted the GDO Blaqs, removed them from Apple Home and re-added them, re-booted both Apple Home Hubs …
I put my Phone on the IoT network so that everything - GDO Blaqs, Apple TV, Apple Homepod, and phone are all on my IoT VLAN.
The issue remains unresolved - when I use the wall buttons to open or close the door, the door open/close status is not correctly updated in Apple Home.
I’m pretty sure it will resolve it. I would recommend trying it on 1 of your devices. Full disclosure, I’m chunking up code to submit PRs to Konnected for both gdolib and gdo-blaq.
Yes, I surmised that you were based on your earlier post. Thats actually good news. Thank you for all of your effort on this.
And yes, version 1.3.7.1 fixes the issues I reported above
