🎉 Introducing HomeKit Native Firmware for the GDO blaQ!
Unfortunately, 1.3.7.1 also spontaneously opened my Security+1.0 Garage Door shortly after 3 am this morning.
Garage Door Opener: Chamberlain Part 41AB050-2M from 2013 (Purple button)
Wall Button Type: Liftmaster 78LM
At around 7am GDO Blaq Diagnostics Web Page shows:
Protocol Security+ 1.0
Up for 3 h 57 m
Last Reset: Panic/exception
GDO Recent Activity shows:
11/1/2026, 3:03:35 AM · system: Firmware booted; history starts here
11/1/2026, 3:03:45 AM · opener: Opening
11/1/2026, 3:03:46 AM · obstruction: Clear
11/1/2026, 3:03:46 AM · opener: Open
11/1/2026, 6:37:43 AM · opener: Closing
11/1/2026, 6:37:53 AM · opener: Closed
I have an updated release that should fix it. What I suspect happened is your device was dropped from your network and reconnected. That reconnect caused a panic/exception on the diagnostic webserver. I had worked on the fix last week as it happened on my garage door too.
Network logs here show a disconnect from the network and a reconnect 25 seconds later right around that time. I’m pretty sure that was the root cause trigger that led to a panic/exception and rest of the problematic sequence for my Security+1.0 door.
you should now be able to update OTA.
Version 1.3.7.2 now running on the GDO Blaq/Door of interest
