Trouble Adopting Device in ESP Home
I installed the GDO Blaq and am running it through Home Assistant but have this error when trying to adopt. I have attempted to do a static IP address to see if that resolves the problem, but I admittedly am not familiar with doing so and everything I have tried doesn’t work. Thank you!
INFO ESPHome 2024.9.2
INFO Reading configuration /config/esphome/konnected-685e08.yaml…
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
See Frequently Asked Questions - ESPHome - Smart Home Made Simple
INFO Generating C++ source…
INFO Compiling app…
Processing konnected-685e08 (board: esp32-s3-devkitc-1; framework: espidf; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
  • framework-espidf @ 3.40407.240606 (4.4.7)
  • tool-cmake @ 3.16.4
  • tool-ninja @ 1.7.1
  • toolchain-esp32ulp @ 2.35.0-20220830
  • toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
  • toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
    Reading CMake configuration…
    Dependency Graph
    |-- gdolib @ 0.0.0+20241002181541.sha.76ba232
    |-- ArduinoJson @ 6.18.5
    |-- Improv @ 1.2.4
    |-- noise-c @ 0.1.6
    RAM: [= ] 14.8% (used 48548 bytes from 327680 bytes)
    Flash: [======== ] 77.6% (used 1423505 bytes from 1835008 bytes)
    ========================= [SUCCESS] Took 16.87 seconds =========================
    INFO Successfully compiled program.
    INFO Resolving IP address of konnected-685e08.local
    ERROR Error resolving IP address of konnected-685e08.local. Is it connected to WiFi?
    ERROR (If this error persists, please set a static IP address: WiFi Component - ESPHome - Smart Home Made Simple)
    ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
