Will not connect to konnected wifi
installed with no problem. in the app it found my 5g connection and not thinking I proceeded. then found the konnected wifi. WILL NOT CONNECT. this is on android. uninstalled the app. reinstalled. tried again using 2.4 wifi. sees the konnected wifi. WILL NOT CONNECT. thought it was my pihole perhaps seeing it as spam. disconnected the pihole. no change. tried with an iphone 13 the only difference is that it says wifi not available now. so the gdo blaq is useless since it wont even connect to its own app wifi.
The GDO blaQ can only see 2.4GHz networks, so it wouldn’t be possible to connect the blaQ to a 5G network.
The Konnected app is used to facilitate sending your home WiFi credentials to the device. Out of the box, the blaQ device is setup to broadcast it’s own WiFi network (captive portal) named konnected-xxxxxx (where xxxxx is a unique identifier). The app first asks you to select your home network and input the password, then will prompt you to connect to the konnected-xxxxx network so it can send over the credentials.
If you’re having trouble connecting to the konnected-xxxxx network, there are a couple workarounds:
  1. Set the WiFi credentials by connecting the device to your computer, launch Chrome browser and go to install.konnected.io. Select the product and firmware platform and click CONNECT. An option to Connect to Wi-Fi should be available.
    Screenshot 2024-06-12 at 11.32.05 AM
  2. You can also use Bluetooth to set the WiFi credentials. Using Chrome or a mobile browser, go to https://www.improv-wifi.com/ and click Connect device to Wi-Fi. Follow the steps to pair with the GDO blaQ and send your WiFi credentials.
  3. If you need to start over (maybe you entered a wrong password or selected the wrong WiFi network) you can always re-flash the device to wipe out any saved settings. Using Chrome browser go to install.konnected.io, select your product, click CONNECT, and then INSTALL.
  4. Using the above process you can also click Logs & Console to stream the logs from the device to see what’s going on with it. You can leave the device plugged into your computer and the Logs & Console open while doing the App wifi setup to see any WiFi related errors. Post them here if you’re still stuck.
EDIT/UPDATE: Got it working. I guess the 5th USB cable was the trick…
Resurrecting this as I fall into #3. I have flashed many a ESP board in my day, but I have tried all the drivers and am unable to connect to the blaQ I received today to reflash it.
Everytime I plug it in the device manager indicates “Unknown USB Device (Device Descriptor Request Failed)”. I tried multiple USB cables.
Hi Nate,
I have three of the blaQ’s and I needed to clean up my Ip address list, so I decided to group the three units together. Two of the units I didn’t have an issue with but one of the units got dropped from the router and I cannot get it to reconnect.
I’m also working with Unifi to see, if they have any ideas why this unit won’t reattach to the router.
I tried what you had noted in the forum but none of it worked. I get trying to connect but stays reporting please wait. One of the other ways it wants me to re-enter the SSID password.
It really seems it wants to stay at 192.168.4.1 (built in IP).
Since the note was about a year ago, I didn’t know, if you have any other suggestions.
Mark
@overwatch there are several ways to connect or reconnect to WiFi, see:
I’m still working with Unifi to get my blaQ to reconnect to my router.
It works fine attaching to hotspots, so I don’t think it is the blaQ.
I’m wondering if there is a factory reset on the blaQ?
All set. Finally got it back online. Router became very mad with the blaQ for some reason.
Have a great day !!!
@overwatch I’m having similar issues - Unfi setup and no luck. #1 and #2 not working for me… can you share any details?
I using UniFi access points and I had to enable “Enhance IoT Connectivity” to get it to work.
This is what the setting say:
“Enhanced IoT Connectivity is enabled, limiting this broadcast to 2.4 GHz only. Please create a separate network for other devices.”
