I had to rebuild my home assistant setup and I’ve gone from v82 to whatever the latest is. This time around, I’m trying to use the GUI as much as possible, and that includes Konnected. I have the binary zones properly setup, but when I go to setup the switchable outputs that are connected to the relays for garage door opening/closing, the Konnected board opens the relays and won’t close them. Now, if your activate the switch, it triggers the relay as it’s supposed to (500ms pulse) and the door activates. BUT, with the regards “stuck” sending out that constant 5v, the physical garage door buttons don’t work. My question is what’s changed either in the versions or in the setup of the Konnected alarm panels?
