I have a Konnected board and one add-on board with 8 zones set up. Every zone is just one door or window sensor. I have removed all the resistors from the old system before hooking up the Konnected boards. I am using Home Assistant as my integration.
I have noticed that the binary sensors are not updating reliably in HASS. Sometimes when i open and close a door it triggers as open, but then doesn't close. I am trying to figure out if the issue is with HASS of Konnected. Is there a way to look at the Konnected board directly and see how it is reacting to opening and closing doors/windows?
