New Firmware Bug
Posting here hoping someone might have some insight into the issue with the new firmware.
I updated the firmware for my konnected alarm panel pros. I have three boards and now have issues with all 3 boards.
The first issue is as follows:
  1. After updating the firmware using a USB cable to my laptop, i am able to connect to the board through the konnected app. I’m able to click on the link “open web page” where i see the status of each of the boards switches and can control the alarm switches “on and off”
The first issue arises when I try to update the firmware through the application. I “build” the the firmware, then once downloaded, I click the update firmware link on the konnected mobile application.
I get a message saying the firmware has been updated. However, I can no longer connect to the board through the “open webpage link” on the konnected app. It says “page not found”. The app still shows it can see the board and the blue light is blinking at a normal interval.
The second problem is that none of my three boards are detected in ESP home in home assistant.
Can you please work on fixing the bug in the new update. I have board versions 1.6 and 1.7. Thank you
SOLVED
I connected each board directly to my router instead of the network switch. Voila - Home assistant can now see the boards.
Same here! Had to give up the wireless feature and use Ethernet cat cable. Not happy about that now I need to fish wire through wall. At least it’s been working since connecting hardwired.
