ESP Firmware / Updated Ethernet Controller
Hello -
Running one of the boards from the batch that had the ethernet issue that has now been reported corrected in 1.8 firmware. Wi-Fi is working flawless, however the preference would be hardwired. I’m using the ESP firmware so it doesn’t failover to Wi-Fi if the ethernet errors somehow persist. As the old saying goes if it ain’t broke don’t fix it, just curious has anyone made the switch over from Wi-Fi to the updated ethernet controller using ESP firmware that can share stability thus far?
Appreciate any feedback.
I’m in the same situation. I haven’t seen confirmation that the fix has been added to the Konnected firmware update page. I tried a few days ago and again this morning without any luck.
I just switched from wifi to ethernet. I can connect and everything feature wise is working so far but I can not update the firmware via the app. I was able to do it via usb though.
