I just received my alarm panel pro and got everything connected. I was going to update the firmware before setting everything up. I’m going the Home Assistant route, so ESPHome I think makes sense. I was surprised that 1.9 isn’t listed on https://install.konnected.io/ for wired connection. Can anyone give me some guidance?
Use the firmware for v1.8. It’s the same.
But you don’t need to update it manually, it already has the ESPHome firmware on it.
