Firmware update fails
Hi,
Hopefully someone can help me with my Alarm Panel Pro.
I upgraded to the ESPHome firmware using the Web Flasher. This worked and I can see it’s web UI and in the Konneccted App.
When I setup the zones and build the firmware (tried both iOS and Android), everything seems to work, even the logs in the web UI suggest a successful install, but after waiting a long time for the device to come back online, I get an error saying “Unable to determine if OTA completed successfully. Please verify your device is online and the new software version 1.2.0.2, is installed”
After this, I can still visit the IP address of the device, but none of the information about the zones etc is shown. It does show logs, version info, and uptime. The logs update from time to time. Updating Heap and Uptime etc
In the Konnected app it shows a yellow warning triangle, and when I go to settings I have the Update Now button shown to me as though it is still expecting an update.
I can also see it in my Unifi UI as being on the network. Strangely though, it shows as a 10GB connection.
Also strange is that after this failed update, I can discover these devices in OpenHAB with the ESPHome binding and it seems to have my zone settings and names. The motion zone appears to work, but nothing from the temperature probe.
I having the same issue. Now my boards aren’t recognized anymore by esp home in HA. Such a pain
SOLVED.
First make sure “LOCAL WEB PAGE API” is enabled. made the mistake of disabeling this a few times in a couple firmware builds.
I tried disconnecting the boards from my network switch and connected them directly to the router. VOILA - they are now seen in home assistant and everything works
