I originally set up my Konnected Pro with Hubitat back in May. I have been trying to get to the updated version, but I am struggling to follow the discussion I have found here so far.
Migration instructions from another thread:
- Flash your device with our ESPHome firmware build from install.konnected.io
- Discover in the Konnected app and set up your zones & preferences
- Follow the steps in the Konnected app to do a wireless firmware update with your zone customizations
- Install the new Hubitat driver either via HPM or using the bundle ZIP provided
- Enter the IP address of the device in the device preferences in Hubitat
- All zones will populate as child devices automatically
See my current setup below. Does this look correct?
I’m actually not sure I succeeded with step 1 as it kept hanging on the “preparing install” screen:
…but my version #s look current/correct (see screen shot below)?
Konnected Pro Current Status
Firmware 1.1.2-795643
Software Konnected Pro 1.3.7
Running and visible in Konnected App (see image below)
Hubitat
Apps Code Installed:
Konnected Pro
Konnected Pro Device
Libraries Code:
espHomeApiHelper
Drivers Code:
Konnected Beep/Blink
Konnected Contact Sensor
Konnected Momentary Switch
Konnected Motion Sensor
Konnected Panic Button
Konnected Siren/Strobe
My alarm panel
6 open/close sensors
2 motion sensors
Note that I can see all of these zones in Hubitat from my original setup back in May, but none are responding to their respective zone activity.
