Matter (beta) updates! GDO blaQ, GDO White and Alarm Panel Pro now with experimental Matter firmware
Yes it does and does not make sense. I like so many people I use an Apple iPad to manage the automation devices in my house. The BLE, matter set up for Hunter douglas, Apple Devices Smarthings, work on iPads. This APP Konnected app combination do not.
I am now in this same situation. Please post any progress you make thanks . One of my APP responds like you state, the other I can’t configure at all.
I determined that Konnected needed to improve the Matter implementation and went back to the original firmware. Once they make changes I’ll try again. To date I have not seen any indication that their firmware has changed.
We would like to use the panel with the Homey Pro hub, which is why we were excited for Matter. The other path is for Konnected to write a Homey app/driver but my understanding is there is not yet enough demand.
Thanks Mark, Good point. I’m looking for another solution. The Konnected firmware has never worked with my Home Assistant or HomeKit reliably.
we just need to convince Nate to write one:)
Right now the Pro board works just fine with SmartThings. It’s one of the last devices to migrate before we can turn off SmartThings…
Ok I just got back from Chicago where @Ryan_P and I attended the Connectivity Standards Alliance member meeting. Matter is picking up momentum and it was refreshing to see the progress being made!
We also had a chance to dig in a little bit on the challenges that you guys have experienced with the Alarm Panel Pro on our Matter beta firmware. Indeed, we have been able to reproduce the stability problems and crashes that you’ve reported after adding ~6 or more zones to the Alarm Panel Pro.
So it turns out that the Matter firmware libraries are quite resource-intensive. We are running into RAM (memory) constraints on the Alarm Panel Pro after about half a dozen or so endpoints/clusters. Part of the problem is also the memory footprint required by the BLE configuration tool that’s running in-parallel with the Matter subsystem.
Basically, the more endpoints/zones we add, and the more Matter controllers commissioned to the device at the same time, add to the bloat and resource strain on the chip. We talked about ways to mitigate this, which is probably going to require a way to switch on/off a “configuration mode” which would enable the BLE config tool while disabling Matter, and “operational mode” which would disable the BLE stack and enable the Matter stack for normal operation. There’s just not enough RAM on the chip to have both running at the same time.
So, that’s in the queue for @Ryan_P to work on shortly. Once that’s ready, we’ll give it another try and hopefully be able to achieve stability with all 15 inputs/outputs populated as Matter clusters with BLE disabled.
@Mark_AppMyHome regarding Homey Pro – unfortunately Homey does not seem to permit uncertified Matter devices, and I’m afraid that Matter certification for the Alarm Panel Pro is going to be a long ways away. There’s currently no Matter specification for a security system device type, and as far as I know this isn’t on any of the near-term roadmaps. We will continue to iterate on the Matter (beta) firmware for the Alarm Panel Pro which should allow us to bridge sensors, switches, etc to Matter controllers that allow uncertified devices, but we won’t be able to invest the time and money into Matter certification until there’s a compelling enough feature set.
@jasleinstein Your use case with Home Assistant and HomeKit seems to be quite different, and with these platforms I would not recommend Matter at this time. Home Assistant should work beautifully and seamlessly with our newest ESPHome based firmware platform, which has native local integration with Home Assistant and supports all features of the hardware and firmware. From there, you can install the HomeKit Bridge integration in Home Assistant to bridge all of your Alarm Panel Pro entities to HomeKit accessories. This is currently the best way to get full feature support for the Alarm Panel Pro into HomeKit. If you’re having trouble getting this working reliably, please open a new topic thread here or contact our support team directly.
Hey Nate, thank you for the excellent explanation. At CES this year we noted that Matter has appeared to have finally arrived, not perfect, but not some exotic feature, more of “yes, we support it”. Sounds like you have a solid path to getting beyond 6 switches.
What is interesting is that Homey Pro doesn’t support uncertified but Apple does. What are the risks to a hub provider to allowing uncertified devices on? Apple seems to not worry, or maybe has the capability to mitigate the risk.
Nate, Mark, Thanks so much for the update. We just need to know the best paths to take. If you think the most solid solution for me is Home Assistant and the ESPHome firmware thats great. For what it is worth, I tried to use the Hunter Douglas Matter support and it is not reliable yet. Im trying to limit my use of Smartthings. HA is becoming my automation platform of choice to support HomeKit which my family loves. thanks
I got everything connected with both APPs and and Home Assistant. Thanks for the help.
I seem to be having issue on all the FWs with things not quite being there. I am hoping for the updates on matter as i think that going to be the best one for me. So keep us updated with your progress.
Currently on the ESP, it mostly works, get this though
Are you still processing matter eap requests?
I thought I had applied some time back, but recently order I and installed a blaq and while the device is working using matter, I can’t connect it in my Konnected app.
I applied again a week or so again in case I was mistaken about previously signing up.
@nate I also applied for matter firmware beta access. Didn’t get any confirmation email so far. Would you be able to check? Also after flashing beta firmware the pairing failed in Hubitat, how to put the device back in paring mode? It’s not flashing blue anymore.
I believe I filled out the Matter form a while ago, and I received an email on Jan 30 that said “You’ve been granted access to the beta. Make sure you’re signing in to the Konnected app with the same email address used when submitting the Matter EAP application.” I’ve filled out the form a couple more times recently. I finally got around to updating one of my two GDO blaqs this morning and I am definitely signed in with the same email where the email was sent, but I don’t see anything in the Konnected app about Matter, so while I was able to add the device to HomeKit, I can’t interact with it in the Konnected app. Please let me know how to proceed.
I just got access to the Matter Beta 2 days ago. I think I applied a couple months ago. So it seems they’re still processing them.
I have two GDO Blaq devices in my garage (one for each door). I’ve upgraded the firmware on both. One paired to Apple Home / Matter and shows up in the Konnected app without issue, but I can’t get the second one to pair or show up. The instructions provide a single Matter pairing code, and when I try to pair the second device, it tells me it already belongs to a home. How do I get the second device set up on matter? The screenshots show two matter devices, which implies it’s possible.
I spent a few more minutes thinking about this and found a solution for whoever comes after me. I unplugged the GDO that was already configured, then went through the pairing process for the second one, which worked fine when only one was powered on. Once the second GDO was set up and added to home, I plugged the first back in and they’re both working fine now. Probably worth adding to the documentation @nate
Matter 1.5 seems to finally add states to GDOs!
Matter 1.5 Finally Adds Support For Smart Cameras and More…
Yes, it’s true! Matter 1.5 is freshly out and one of the new features it includes is closures which are an abstract way to define devices that open and close, including garage doors!
We’ve been waiting for this for sure!
Although the wait still continues as of now it seems that Espressif’s open-source SDK for Matter doesn’t quite yet have all the closure support. It definitely takes a while after the spec is released for all the platforms and libraries to catch up with the new functionality.
But yes, Matter 1.5 was the un-blocker that we were waiting for as a path to certification of the GDOs.
@Ryan_P Is tasked with the firmware dev for this. Do you have any updates or status to share?
Nothing solid yet, but it looks like espressif has started adding the closure controls, hopefully be able to test something soon.
I’ve been eagerly awaiting this moment, hoping the new 1.5 experimental firmware will arrive as soon as possible.:clap: :clap:
