I have this setup in my house (CAME 002scp8096alarm) :
external Siren
internal Siren
doors and windows sensor
keyboard for manual arming
RFID in the entrance of my house
I want to install konnected in parallel with the right kit. what i have to buy? i need to mantein all the old setup. I want only to arm and disarm with my phone (home assistant).
It seems you’re interested in integrating your current alarm setup with Konnected for smart control via Home Assistant. To maintain your existing setup while adding smart capabilities, I recommend the Konnected Alarm Panel Pro Interface Kit. This kit allows you to keep all your current equipment, including sirens, sensors, and keypads, and simply add smart functionalities for arming and disarming your system via your phone.
Unfortunately, I can’t determine the exact number of zones you’ll need from your photos/description. Each “zone” typically corresponds to an individual sensor or a group of sensors. To ensure you choose the right kit, you might want to count how many separate sensors or sensor groups you have.
Here’s what you need:
List item
Konnected Alarm Panel Pro 12-Zone Interface Kit: This kit offers 12 zones, which should be ample for most home setups. It supports Ethernet or Wi-Fi connectivity and integrates with various smart home platforms, including Home Assistant. It also includes outputs for sirens and strobe lights, providing versatile installation options.
Ensure you have the “installation code/engineer code” for your existing alarm system, as you’ll need it to program one of the outputs as a key switch, enabling remote arming and disarming through Home Assistant.
You can find more detailed information about the product in the Konnected Product Offerings Overview.
