Can I use Interface Kit to replace an old alarm system?
Hi,
Years ago, I bought a Konnected Interface Kit to integrate sensors of my existing Bosch Easy Series alarm system in Home Assistant. This worked great.
Now, I would like to replace the aging Bosch system by a new one. And then completely remove the Bosch system. But I would like to still use the sensors of this old system in my Home Assistant. I would like to know if I could connect them to my existing Konnected Interface Kit ? If it is possible, what I should do ?
As I understand, the Interface Kit contains a Konnected Add-on Panel, then can I just connect the sensors directly to this panel (following the documentation) ? Am I right ? Or should I buy a new Konnected Convertion Kit ?
Is it possible to connect a siren to the Add-on Panel ?
Thanks.
