I followed the instructions here: https://support.konnected.io/door-toggle-relay-trigger-on-the-gdo-blaq to enable the external toggle but it’s not working. I have checked my wiring and it seems okay, I tried both inputs since they’re not labeled 1 and 2 on the unit but it still doesn’t do anything and I don’t see anything in the logs. I even copied the code from the remote file directly into my config and added a logger message for when the external button is pressed and that is never fired, it seems that the input is never detected. What else could I be missing?
If you have one of the first batch of GDO blaQ (with two gray dots instead of ① and ② terminals), it may not work due to a hardware issue that was fixed in the next revision. What’s the batch number of your GDO blaQ?
If this is the case and you need this feature, we can swap it out for a new one for you.
Same. Must be one of the first batches because I only have grey dots and I couldn’t get either one to function.
My batch number is 2404. I had an old MyQ smart button that wasn’t working well so I was trying to replace it with a dumb button instead of having to buy a new one.
@Textonly @DrMikeOxlong please DM me or email help@konnected.io with your order number or Amazon receipt and a photo of the device with two gray dots and I will send you an updated model replacement.
