Chamberlain 41A6318 Garage Door Opener Wall Control
Good to know, thank you!
Just for reference, I have another location with a Lift Master on Security 2.0+ and was considering replacing the wall control with this one:
There are other threads on here that seem to report similar weird issues.
It seems that adding the blaQ to the circuit just puts a little too extra load on the wires (even though it has its own power supply), that causes issues with that wall control panel (although in my research, it seems the capacitors inside it can fail as well).
Seems to affect the motion sensor ones as well, but to a much lesser extent.
