Can't get Temp Probes to SmartThings
This is a new installation of an Alarm Panel Pro. All the door and motion sensors work fine and show at SmartThings for the security monitor. However the two temp probes do not. They show temp correctly on the panel web page. I have gone through the Kai suggestions many times and still they don’t show at SmartThings under Devices. The 8 door sensors and motions sensor show and respond fine at ST. I have deregistered and reregistered the panel from Konn Cloud several times, and unlinked/relinked Konnected from ST several times. Rebooted the panel by the button and by the web page. Added Devices via ST-Konnected many times.
The panel is connected by wifi, and otherwise seems fine. Temp probes are connected per the diagram with the resistor and do correctly track temp.
What else can I do to debug this? Either at the board, at Konnected Cloud, or ST app settings, or ST-Konn link?
Thanks.
Oh, and the probes are connected to Zones 1 and 2.
Well, without me doing anything the temp probes now show up today in SmartThings after nearly two months
Inexplicable, since I haven’t even been home to fiddle with anything for 6 weeks. Just suddenly the temp probes show up under devices and the logged data is there under History
Does anyone know if there was a backroom reset or update at SmartThings or Konnected?
:waving_hand:
I found a bug in our back-end that was related to the temp probes discovery and fixed it last week.
OK. Great to know. Thanks. :+1:
This will open up several automation possibilities for me.
