I am able to start the setup with the app on my phone. I am able to connect to the board and setup the wifi. After that the app shows Status: Unreachable. I can see that is got an IP from my router. When I check my router it is not showing the board online.
I have factory reset the board a couple times by jumping zone 1 and 2. This has allowed me to start the setup over but I end up with the same issue.
I was finally able to get it to connect and it showed up in my router using the RESTClient method. But after a couple moments it went offline and the blue light started flashing on the board again. It is broadcasting it’s own SSID again.
I can also no longer get it to setup in the app. It gets to the point of setting up the wifi the just hangs there and never actually adds itself to the app.
