I am having the SSL/DuckDNS issue (sensor changes not detected) with hass.io 0.75.1 despite using the api_host setting and figure I need to upgrade the Konnected board. Not sure what version is on it, it was delivered a few weeks ago. However, when I run the Konnected flash tool, it says: “not compatible with the version of Windows you are running”. I have tried it on Windows 10 and Windows 8. I can’t imagine it would not work with any of these versions, so probably something else is wrong. Do I need to install Python separately? Or some other component? Nothing like that is mentioned in the How-to.
Related topics
| Topic | Replies | Views | Activity | |
| Firmware Update Does Not Connect? | 7 | 301 | May 26, 2020 | |
| Getting an error while trying to reflash the GDO White (v2 I think I just got it) | 2 | 145 | April 24, 2024 | |
| Several problems with konnected and hassio | 2 | 198 | August 1, 2018 | |
| Konnected Pro: Help updating previous install to latest ESPHome firmware | 2 | 552 | January 17, 2025 | |
| Konnected "failed to setup" message in Home Assistant | 1 | 297 | February 25, 2024 |
