Trying to trigger pin with CURL causes reboot
I'm trying to trigger the OUT (pin 8) manually using CURL and the REST API to test a buzzer but my unit just reboots.
Here is my curl command:
curl -H "Content-Type: application/json" -d '{"pin":8, "state":1, "momentary":1000}' http://192.168.0.93:13880/device
curl: (56) Recv failure: Connection reset by peer
And here is the console output...
Konnected firmware 2.3.0
NodeMCU 2.2.0.0 build 20190805 powered by Lua 5.1.4 on SDK 2.2.1(6ab97e9)
Heap: 41712 Initializing Konnected (2cf43259bb88)
Heap: 40736 Application Version: 2.3.5
Heap: 39568 Connecting to Wifi..
> Heap: 42240 Wifi connected with IP: 192.168.0.93 Gateway: 192.168.0.1
Heap: 42064 Current Date/Time: 2020-08-14 11:28:01 UTC
Heap: 41976 Booting Konnected application
Heap: 41888 UPnP: Listening for UPnP discovery
Heap: 41408 HTTP: Starting server at http://192.168.0.93:13880
Heap: 41240 Loaded: server
Heap: 39376 REST Endpoint: nil
Heap: 39328 Loaded: application
Heap: 37720 HTTP: Device
PANIC: unprotected error in call to Lua API (/opt/lua/httpd_res.lua:7: bad argument #1 to 'len' (string expected, got nil))
 ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 27760, room 16
tail 0
chksum 0xd4
load 0x3ffe8000, len 2340, room 8
tail 12
chksum 0x5f
ho 0 tail 12 room 4
load 0x3ffe8924, len 136, room 12
tail 12
chksum 0x84
