Panel Pro constantly rebooting (and buzzer chirping)
Good evening,
Last fall, I installed a panel pro to replace my old alarm system board and I’ve been having an issue since then that I’m only now trying to address.
The Panel Pro is constantly rebooting. The uptime showed in the Status Page rarely exceeds a couple of minutes. This behaviour appears to be inconsistent and happening more frequently some times than others. At each reboot, the buzzer will emit a short chirp (which can be a bit annoying when it reboots every minute).
The Panel Pro is driven by the Homebridge Konnected plugin version 1.3.2.
The Panel Pro itself is hardware version 1.9, firmware 1.1.2. It is connected to the network ethernet and powered with the power adaptor (not PoE). The buzzer is connected on zone 1 and otherwise works as expected.
Any advice on how I could resolve this issue?
Thank you!
