Hi I have just setup my new alarm panel pro interfacing with my previous alarm. The Alarm Panel Pro is set to use wifi and reboot frequently according to HomeAssist. The wifi signal is good and has been upgraded to the latest ESPHome firmware. When it is connected everything seems fine.
Hi All. I’m having a similar problem, but with Hubitat. My logs are full of
“ESPHome sending message type #1 (4 retries left)”
”ESPHome requesting API version”
eventually, ESPHome runs out of retries and closes the socket, then starts all over.
Also, lots of “Heap Free” sending state notifications in the log for the panel.
I suspect it is because I’ve “rebuilt” the firmware for the alarm panel too many times as I iterated through the setup. While I don’t relish the idea of starting over, should I start over? And does that mean a factory reset?
Thanks in advance for your help.
Update your Hubitat drivers/libraries to the latest Konnected ZIP bundle from here:
Thanks for the quick reply! I appreciate it.
I’ve updated the drivers/libraries, and updated the platform for the hub. It still seems to be cycling. Here’s a snippet of the log I see from the hub-side (edited with Xs where necessary):
2025-12-12 01:41:26.527 PM
info
XXXX is offline: message retry count exceeded
**dev:3**2025-12-12 01:41:26.524 PM
info
ESPHome closing socket to xxxx
**dev:3**2025-12-12 01:41:26.489 PM
info
ESPHome message type #7 retry count exceeded
**dev:3**2025-12-12 01:41:21.466 PM
info
ESPHome sending message type #7 (0 retries left)
**dev:3**2025-12-12 01:41:21.464 PM
info
Subscribing to ESPHome device states
**dev:3**2025-12-12 01:41:21.462 PM
info
Subscribing to ESPHome INFO logging
**dev:3**2025-12-12 01:41:21.460 PM
info
Subscribing to ESPHome HA services
**dev:3**2025-12-12 01:41:17.702 PM
info
ESPHome sending message type #9 (3 retries left)
**dev:3**2025-12-12 01:41:17.700 PM
info
ESPHome sending message type #7 (1 retries left)
**dev:3**2025-12-12 01:41:12.678 PM
info
ESPHome sending message type #9 (4 retries left)
**dev:3**2025-12-12 01:41:12.676 PM
info
ESPHome sending message type #7 (2 retries left)
**dev:3**2025-12-12 01:41:07.608 PM
info
XXXX is online: connection completed
**dev:3**2025-12-12 01:41:07.605 PM
info
ESPHome sending connect request (no password)
**dev:3**2025-12-12 01:41:07.604 PM
info
ESPHome device name: konnected-38182b546c98
**dev:3**2025-12-12 01:41:07.602 PM
info
ESPHome server info: 2025.11.5
**dev:3**2025-12-12 01:41:07.599 PM
info
ESPHome API version: 1.13
**dev:3**2025-12-12 01:41:06.812 PM
info
And a snippet of the logs from the alarm panel:
| Time | Level | Tag | Message |
| 13:46:42 | [I] | [app:190] |
ESPHome version 2025.11.5 compiled on Dec 10 2025, 17:05:35
| 13:46:42 | [I] | [app:192] |
Project konnected.alarm-panel-pro version 1.2.2.9
| 13:46:42 | [C] | [logger:261] |
Log
| 13:46:42 | [C] | [logger:267] |
Log Baud Rate: 11
| 13:46:42 | [C] | [logger:274] |
Task Log Buffer Size: 768
| 13:46:42 | [C] | [logger:280] |
Level for 'json': INFO
| 13:46:58 | [C] | [template.text_sensor:016] |
Template Sensor 'Device ID'
Template Sensor 'Project version'
| 13:46:58 | [C] | [uptime.sensor:017] |
Uptime Sensor 'Upt
| 13:46:58 | [C] | [uptime.sensor:027] |
Device Class: 'duration'
| 13:46:58 | [C] | [uptime.sensor:031] |
Icon: 'mdi:timer-outline'
| 13:46:58 | [C] | [uptime.sensor:033] |
Type: Seconds
| 13:46:58 | [C] | [status_led:063] |
Status Led Light:
| 13:46:58 | [C] | [status_led:064] |
Pin: GPIO3
| 13:46:58 | [C] | [gpio.binary_sensor:018] |
GPIO Binary Sensor 'Inside Garage Door'
| 13:46:58 | [C] | [gpio.binary_sensor:021] |
Device Class: 'door'
| 13:46:58 | [C] | [gpio.binary_sensor:072] |
Pin: GPIO4
| 13:46:58 | [C] | [gpio.binary_sensor:073] |
Mode: interrupt
| 13:46:58 | [C] | [gpio.binary_sensor:075] |
Interrupt Type: ANY_EDGE
| 13:47:14 | [C] | [gpio.binary_sensor:018] |
GPIO Binary Sensor 'External Garage Door'
| 13:47:14 | [D] | [sensor:133] |
'Heap Free': Sending state 211712.00000 B with 0 decimals of accuracy
'WiFi Signal RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
'WiFi Signal %': Sending state 72.00000 % with 0 decimals of accuracy
| 13:47:15 | [D] | [sensor:133] |
'Uptime': Sending state 4384.29688 s with 0 decimals of accuracy
'Heap Free': Sending state 213000.00000 B with 0 decimals of accuracy
| 13:47:55 | [D] | [sensor:133] |
'Heap Free': Sending state 213192.00000 B with 0 decimals of accuracy
| 13:47:56 | [D] | [sensor:133] |
'WiFi Signal RSSI': Sending state -63.00000 dBm with 0 decimals of accuracy
'WiFi Signal %': Sending state 74.00000 % with 0 decimals of accuracy
| 13:49:08 | [D] | [sensor:133] |
'Uptime': Sending state 4444.29883 s with 0 decimals of accuracy
| 13:49:21 | [D] | [sensor:133] |
'Heap Free': Sending state 207348.00000 B with 0 decimals of accuracy
'Heap Free': Sending state 206924.00000 B with 0 decimals of accuracy
| 13:49:22 | [D] | [sensor:133] |
'Uptime': Sending state 4504.29980 s with 0 decimals of accuracy
'Heap Free': Sending state 206460.00000 B with 0 decimals of accuracy
| 13:49:32 | [D] | [sensor:133] |
'Heap Free': Sending state 216192.00000 B with 0 decimals of accuracy
@Mark_Crescenzi I’m pretty sure that your issue is the same issue as described here, which should be fixed by updating the ESPHome library in hubitat:
