Hi All,
I'm just getting set up with my Konnected.io installation and I seem to be having some problems with state changes of door/window sensors and motion sensors reflecting in the SmartThings app.
I have three door sensors, two window sensors, one motion sensor and a siren wired up currently. I see immediate state changes from closed->open->closed on one of the three doors, the windows, and when i turn the siren on and off manually it's state reflects properly in the app.
With the other two doors, they will show as Closed in the app, then when I open them they'll change to Open immediately, but then will never change back to Closed. When I observe the Live logs the"contact closed" event is logged but the sensor status shows as Open in SmartThings, unless I power cycle the Konnected board. In this case the default state is Closed for all door/window sensors.
The motion sensor is similar. It starts off as "No Motion", then when there is motion will change to "Motion" I see a Live log for "A sensor event occurred" [name:motion......" and the sensor changes to "Motion" in SmartThings, but then will never revert back to "No Motion".
I've tried to set the Normal State on all sensors to "Normally Open" but this doesn't seem to make a difference. Has anyone got any clue where the disconnect is? My house is a 90s build and I see no resistors anywhere in the existing wiring.
Thanks!
