Pro Board Siren 01/02 (possible malfunction)
Hi, on my new Pro board I have 1 siren attached to each of the two connectors as outlined in the configuration documentation. Both are configured the same other than the name (1=Inside / 2=Outside)
My testing shows that only siren ONE works fine, and the red LED on the board illuminates; siren TWO does nothing. No power, no led.
Any thoughts? Thank you!
Make sure that the toggle switch above the terminal block is in the “ALARM 2” position.
Only ALARM2 or OUT2 can be enabled at any one time.
Thank you, Nate. I am finally hooking up the wires for my alarm as the last step in my config. That did the trick - both sirens work fine now. I appreciate the quick response.
