I wired two piezo buzzers one on each of the outputs. When turning one on, the other stops sounding regardless of the order in which they are turned on.
Is it expected that only one of two outputs can be active at the same time? If so, is this something that could potentially be fixed with a firmware update?
Yes, they should be controllable independently. Can you give me some more details about your configuration/setup of those outputs and what platform you’re using so I can try to reproduce?
