Power Brick Upgrade for Garage Openers
The most common mounting location for power at garage door openers is a ceiling mounted box overhead. This is almost exclusively the case for drywalled garages.
The shipped power Brick has nothing to secure the brick except the strength of the receptacle contacts against the prongs themselves. This is an accident waiting to happen, especially given the minor vibration involved each time the door is operated, or installation with an older receptacle that may have worn contacts.
I would think the ideal case is a wall wort with a longer screw that can replace the center cover plate screw and secure the whole thing to a duplex receptacle, while leaving the other receptacle open. My old alarm panel had a power brick like this. Failing that, at minimum include a strap to prevent it from falling out, damaging a car, and resulting in a bunch of small claims lawsuits!
Dressing the power cable out to the opener’s motor unit support with wire ties would actually keep the adapter from fully dropping in the scenario you portray. Kindof like a safety harness for the adapter. I actually didn’t want to have another plug up on the ceiling and a cable to dress out, so I actually sourced my power from inside the power unit at the header cable between the logic board and the relay board, and then made an exit from the side of the case. Photo below:
The so called brick doesn’t weigh any more than the plug from your opener. If you are so concerned that the brick will eventually fall, Ty-wrap the cord to your opener cord!
Yes! I think a secure mounting solution for the power block is essential, especially with the vibration from the garage door. Your idea of a wall outlet with a longer screw sounds practical and could prevent accidents. Safety first!
@Mike_Knittel I would love to see a pic of where you sourced the 12V from the opener motor if you have one!
