Opening/Closing/Position Status intermittent
Hello! I have been using the GDO BlaQ with Homeseer and AlexBK66’s plugin for quite awhile now and it’s been great. Recently I decided to add some lighting effects to automatically play while the door opens and closes. Unfortunately, it seems that the GDO BlaQ is inconsistent about sending “opening” “closing” and position updates. I though at first it was only when using the wall button or the car remote, but it also isn’t perfect when commanded from Homeseer. The status is consistently good about Open or Closed, when motion is complete, but the actively moving states only come through about half the time. Logs from AKKonnected match the status updates I’m seeing in Homeseer, is there a way to check past logs on the GDO BlaQ, or do I just have to watch the realtime log on the GDO BLaQ webpage?
My Konnected GDO BlaQ settings:
ESPHome version 2025.10.5
Project Version 1.5.4.4
Konnected Cloud Disabled
Local Native API Disabled
Local WebPage / API Enabled
Network Wifi
Pre-close warning Ominous
Extra Input/Output Disabled
Homseser V4.2.22.4
AKKonnected Plugin v 4.0.1.53
Most “Child Device” settings are at 1 or 2 seconds.
