I had all the sensors updating without a problem locally (before duckdns SSL). I'd like to get everything working over duckdns SSL so that I can remotely monitor and set my alarm system.
I believe I have the port forwarding setup correct (TCP 443->443 and TCP 8123->8123 for the raspberry pi IP) and I am able to establish connection from my duckdns domain to my raspberry pi hassio server. Below is a snapshot of my 5 zones from HA (produced from http://<my_domain>.duckdns.org):
I ran the logger for the konnected device and was able to query the software/firmware versions from the http://<konnected IP>:<randomized_port> which is below:
konnected software version: 2.2.6
- konnected firmware version: 2.2.6
- API Endpoint: https://<my_domain>.duckdns.org:8123/api/konnected
What I think are the important bits of my configuration.yaml is below:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc. http: base_url: https://<my_domain>.duckdns.org:8123 ssl_certificate: /ssl/fullchain.pem ssl_key: /ssl/privkey.pem api_password: !secret http_passwordkonnected:
api_host: https://<my_domain>.duckdns.org:8123
access_token: blahblah
devices:
- id: <konnected MAC address>
binary_sensors:
- zone: 1
type: door
- zone: 2
type: window
- zone: 3
type: door
- zone: 4
type: window
- zone: 5
type: window
name: Upstairs Back Windows
In addition to Duck DNS add-on, I also installed the NGINX Home Assistant SSL Proxy. The configuration for that is below:
Has anyone else run into this before and could give me some advice?
Thanks!
