I am replacing my old (and non-working) house alarm for a konnected device linked to my Home Assistant (RPi2 and Hass.io). As the konnected device I am using a NodeMCU Lolin with a DIY base-board. I followed all the steps in the konnected.io website and was able to flash the NodeMCU with the konnected-firmware-2-2-6.bin plus upload all src files to the board with ESPlorer. After reseting the device, I connected to its wi-fi network and fixed up my home SSID and password. The NodeMCU connected to my router, and I reserved a static IP to its MAC address. The connection appear to be pretty solid.
After that, I mounted the NodeMCU, a siren (in a relay module), and a 12V UPS in a metal case. Since I didn't had the wiring cables for the sensors at hand, I decided to simulate them (plus a piezzo buzzer) in a prototyping breadboard for testing purposes.
I edited the configuration.yaml to create the entities for 5 zones, siren and buzzer. Upon Hass.io restart, all these entities shown up in Home Assistant. The problem is, all binary sensors appear closed (as expected), but when a sensor circuitry is opened for testing, Home Assistant don't show the state change. When I try to turn on the buzzer or siren manually, nothing happens.
With the Arduino IDE serial monitor, I was able to find the network port from the konnected device, so I am certain it is functional and online. However, the "Configuration Information" fields are blank, except the 'API Endpoint' witch is "Undefined". This led me to wonder if it is a Hass.io Discovery issue, but I think I correctly filed the configuration.yalm konnected section:
konnected:
access_token: XXXXXXXXXXXXXXXXXXX
api_host: http://XXX.XXX.XXX.XXX:8123
devices:
- id: XXXXXXXXXXXX
host: https://XXX.XXX.XXX.XXX
port: XXXXX
discovery: false
binary_sensors:
- pin: 1
type: door
- pin: 2
type: door
name: 'Laundry / Piano Studio'
- pin: 5
type: window
- pin: 6
type: door
- pin: 9
type: motion
name: 'Living Room Movement'
switches:
- pin: 7
momentary: 65
pause: 55
repeat: -1
- pin: 8
name: sirenCan anyone point me a way? I am clueless on how to proceed to make this konnected setup work, and any help is welcome.
