I just upgraded to the latest version of Hassio and now my integration page shows them as new devices. I need to add an IP and a port.
Is this normal behaviour? If so, I am unsure of the port number.
+1 on this. My Konnected panel is now broken. I have three Konnected boards and each is detected by Home Assistant in Configuration. However, it isn't clear what I am supposed to do to get them working again.
Figured it out. You can download the Konnected smart home app on your phone and you can scan and see the ip and port number in there
Aha - OK. I have never used the app! Each of my Konnected boards looks identical in HA. How did you figure out which is which or does it matter?
So mine still won't work. I updated firmware but the app still shows that I need a firmware update. The IP+Port combos from the app don't work in setup. What a mess - no security system now for a few weeks and zero documentation that I can find on how this is supposed to work.
I only have one board so I can't tell you how to know which is which. They should have different MAC addresses, so hopefully you can figure out which is which from that. Maybe power cycling the Konnected boards might help? Mine connected fine when I put in the IP and port from the app, and my Konnected board and HA server are on different subnets, so my setup is more complicated than most.
I'm also seeing errors on HA boot now... latest version of hass.io and latest Konnected firmware both installed
2020-03-10 23:40:31 WARNING (MainThread) [homeassistant.config_entries] Config entry for konnected not ready yet. Retrying in 5 seconds.
2020-03-10 23:40:44 WARNING (MainThread) [homeassistant.components.konnected.panel] Exception trying to connect to panel: Cannot connect to host 192.168.1.174:11221 ssl:None [Connect call failed ('192.168.1.174', 11221)]
2020-03-10 23:40:44 WARNING (MainThread) [homeassistant.config_entries] Config entry for konnected not ready yet. Retrying in 10 seconds.
2020-03-10 23:40:44 WARNING (MainThread) [homeassistant.components.konnected.panel] Exception trying to connect to panel: Cannot connect to host 192.168.1.116:11218 ssl:None [Connect call failed ('192.168.1.116', 11218)]
I am also receiving this error
Exception trying to connect to panel: Cannot connect to host appears since 107... my firmware was well out of date, so worked with Andy from support to update, but still unable to connect.
I do have a legit SSL assigned to my HA however so maybe its something to do with that?
Check the status in your Konnected mobile app for the "Endpoint" value is not syncing over as the external facing DuckDNS hostname
To resolve, make sure you set the api_host variable in the Konnected section of your configuration.yaml to the internal IP and port of your Home Assistant instance. You may need to delete the Konnected integration from the HA user interface, and re-do the discovery/setup.
Example configuration.yaml
konnected:
access_token: !secret konnected
api_host: http://10.0.0.154:8123
Check the status in your Konnected mobile app for the "Endpoint" value and make sure that it is not syncing over as the external facing DuckDNS hostname
konnected:
.. Example configuration.yaml ..
I don't have this in configuration.yaml
Should I?
I am not sure if this is my issue or not. I cannot connect to the WIFI. It logs in for while, can ping it on the WIFI network then it seems to just disconnect.
OK, I have found this in the logs:
2020-12-16 11:23:14 ERROR (MainThread) [homeassistant.components.konnected.panel] Exception trying to get panel status: Cannot connect to host 192.168.1.55:12108 ssl:default [Connect call failed ('192.168.1.55', 12108)]
I have:
Just an update. I found the address should be https:// and not http://
