Network connectivity
While attempting to add my Blaq v2 after connecting to a WiFi network and receiving the “All set” dialog, setup stays stuck at the “waiting for WiFi. Waiting for this phone to connect the setup network”.
It never reconnects to the konnect-xxxx network and my router, konnect app, or smarthings app can’t find it.
If you got the “All set” message (and the password was correct) then the device will no longer broadcast the konnected-xxxxx network and it should be connected to your WiFi.
It should now just show up in your My Devices list, or you can go back to Add a device and tap Discover Devices (skipping the WiFi provisioning step) to find it on the network.
If that doesn’t work right away, try completely exiting the Konnected App and re-launch it, and try again.
