I've got two Konnected devices that are only sometimes detected by Home Assistant. I usually have to reboot Home Assistant 2 or 3 times before the devices are found, then they work perfectly for days until I have to reboot, when it may or may not need to be restarted 2 or 3 times again.
I'm running Home Assistant in a Docker container on my unRAID system. The same issue was present when running it in a Docker container on my old Ubuntu server.
I've tried leaving it over an hour to detect them, but it never does.
I'm suspecting the Home Assistant is to blame here, since the two different Konnected devices are both having the same issue at the same time. Home Assistant is 0.73.1, both Konnecteds are 2.2.1.
Here are the Home Assistant logs, first for a boot that did not detect them, then a successful one. They're less than a minute apart, but like I said, I've left it for quite a while and they are never detected.
2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=check_config> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=dismiss> 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger 2018-07-13 16:43:15 INFO (MainThread) [homeassistant.setup] Setting up logger 2018-07-13 16:43:15 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.2018-07-13 16:43:37 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Discovered a new Konnected device: {‘host’: ‘192.168.1.13’, ‘port’: 13463, ‘ssdp_description’: ‘http://192.168.1.13:13463/Device.xml’, ‘name’: ‘Konnected’, ‘model_name’: ‘Konnected’, ‘model_number’: ‘2.2.1’, ‘serial’: ‘5463192’, ‘manufacturer’: ‘konnected.io’, ‘udn’: ‘uuid:8f655392-a778-4fee-97b9-4825918535c98’, ‘upnp_device_type’: ‘urn:schemas-konnected-io:device:Security:1’}
2018-07-13 16:43:37 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Discovered a new Konnected device: {‘host’: ‘192.168.1.6’, ‘port’: 9674, ‘ssdp_description’: ‘http://192.168.1.6:9674/Device.xml’, ‘name’: ‘Konnected’, ‘model_name’: ‘Konnected’, ‘model_number’: ‘2.2.0’, ‘serial’: ‘1674609’, ‘manufacturer’: ‘konnected.io’, ‘udn’: ‘uuid:8f655392-a778-4fee-97b9-4825918198d71’, ‘upnp_device_type’: ‘urn:schemas-konnected-io:device:Security:1’}
2018-07-13 16:43:38 INFO (SyncWorker_7) [homeassistant.components.konnected] Initialized Konnected device 84f3eb535c98
2018-07-13 16:43:38 INFO (SyncWorker_8) [homeassistant.components.konnected] Initialized Konnected device dc4f22198d71
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Configuring Konnected device 84f3eb535c98
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Configuring Konnected device dc4f22198d71
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Set up sensor North Garage Door (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Set up sensor Front Door (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Set up sensor Side Door Lock (initial state: True)
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Set up sensor Back Door (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Set up sensor South Garage Door (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Set up sensor Garage Entry Door (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Set up actuator North Garage Door Relay (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Set up sensor Computer Room Windows (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] Storing data in hass.data[konnected]: {‘client’: <konnected.Client object at 0x1511e9cac128>, ‘binary_sensors’: {1: {‘type’: ‘garage_door’, ‘name’: ‘North Garage Door’, ‘state’: None}, 2: {‘type’: ‘lock’, ‘name’: ‘Side Door Lock’, ‘state’: True}, 6: {‘type’: ‘garage_door’, ‘name’: ‘South Garage Door’, ‘state’: None}}, ‘switches’: {5: {‘name’: ‘North Garage Door Relay’, ‘state’: None, ‘activation’: ‘low’}}, ‘host’: ‘192.168.1.13’, ‘port’: 13463}
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Set up sensor Kitchen Window (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] 84f3eb535c98: desired sensor config: [{‘pin’: 1}, {‘pin’: 2}, {‘pin’: 6}]
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Set up sensor Nook Window (initial state: None)
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] 84f3eb535c98: current sensor config: [{‘pin’: 1}, {‘pin’: 2}, {‘pin’: 6}]
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] Storing data in hass.data[konnected]: {‘client’: <konnected.Client object at 0x1511e8168e48>, ‘binary_sensors’: {1: {‘type’: ‘door’, ‘name’: ‘Front Door’, ‘state’: None}, 2: {‘type’: ‘door’, ‘name’: ‘Back Door’, ‘state’: None}, 5: {‘type’: ‘door’, ‘name’: ‘Garage Entry Door’, ‘state’: None}, 6: {‘type’: ‘window’, ‘name’: ‘Computer Room Windows’, ‘state’: None}, 7: {‘type’: ‘window’, ‘name’: ‘Kitchen Window’, ‘state’: None}, 9: {‘type’: ‘window’, ‘name’: ‘Nook Window’, ‘state’: None}}, ‘switches’: {}, ‘host’: ‘192.168.1.6’, ‘port’: 9674}
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] 84f3eb535c98: desired actuator config: [{‘pin’: 5, ‘trigger’: 0}]
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] dc4f22198d71: desired sensor config: [{‘pin’: 1}, {‘pin’: 2}, {‘pin’: 5}, {‘pin’: 6}, {‘pin’: 7}, {‘pin’: 9}]
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] 84f3eb535c98: current actuator config: [{‘trigger’: 0, ‘pin’: 5}]
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] dc4f22198d71: current sensor config: [{‘pin’: 1}, {‘pin’: 2}, {‘pin’: 5}, {‘pin’: 6}, {‘pin’: 7}, {‘pin’: 9}]
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] 84f3eb535c98: desired api endpoint: http://192.168.1.21:8123/api/konnected
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] dc4f22198d71: desired actuator config: []
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] dc4f22198d71: current actuator config: []
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] dc4f22198d71: desired api endpoint: http://192.168.1.21:8123/api/konnected
2018-07-13 16:43:38 DEBUG (SyncWorker_7) [homeassistant.components.konnected] 84f3eb535c98: current api endpoint: http://192.168.1.21:8123/api/konnected
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] dc4f22198d71: current api endpoint: None
2018-07-13 16:43:38 DEBUG (SyncWorker_8) [homeassistant.components.konnected] pushing settings to device dc4f22198d71
2018-07-13 16:43:48 WARNING (MainThread) [homeassistant.setup] Setup of wemo is taking over 10 seconds.
Any help appreciated.
