Konnected add on board disconnecting from wifi
I have a Konnected Alarm Panel 2 with a single Alarm Panel 2 Add-on. Recently, the Alarm Panel 2 Add-on has been having connection issues with the WiFi. It connects to the network for a few seconds and then disconnects and goes into pairing mode. This is new behaviour and it was working for the first couple of weeks. I have one other AP that is further away so I disabled that in case it was getting confused but it still has the same issue. The Konnected Alarm Panel 2 has no issues connecting and staying connected.
Is this a hardware issue? What other troubleshooting can I do?
Embedding the video didn't work but here is a screencast showing the connection issue. Notice, the other board has no issues staying connected and they are right next to each other and LoS from the router.
https://youtu.be/Mn2bbvMCP7w
I held down the reset button for 30s. The device then connected and has remained connected for 2hrs now. Thanks for your help via email Andy!
I’m running into the same issue. Any resolution?
I’ve tried holding the reset button down for 30 seconds to no avail
Hi, I was suprised that there was no follow-up on this topic. What wat the outcome? I am experiencing the same :frowning:
I got new panels recently and facing the same issue - the panels refused to stay connected. Power cycling them makes it work but it’s like 2/3 times they stay on that blinking blue LED status
Please share some logs so we can see what’s going on. Often times the WiFi going in and out can be a symptom of a different problem that’s not WiFi related at all – for example the device might be rebooting which makes it appear that it is dropping off of WiFi frequently.
Logs will help us determine the root cause.
