Having a issue here. I’m getting a error message when trying to close the garage door. It is claiming the garage is already closed when it is in a open state. When I hit the “down arrow” in the GDO’s web page or via the Home Assistant entity. The “stop” icon will initiate closing the door.
Two things, the garage is always in a “closed” state on the second line of the web page. Then the wired Sensor is in a “off” state when closed, and a “on” state when open. Shouldn’t this be inverted? on for closed and off for open?
Wondering if something is messed up in the yaml config for firmware. Was working since October and broke earlier this week.
Thanks.
I get this in the logs.
| 13:52:09 | [D] | [sensor:093] | ‘Sensor distance’: Sending state 0.63100 m with 2 decimals of accuracy |
| 13:52:12 | [D] | [vl53l0x:310] | ‘Sensor distance’ - Got distance 0.635 m |
| 13:52:12 | [D] | [sensor:093] | ‘Sensor distance’: Sending state 0.63500 m with 2 decimals of accuracy |
| 13:52:14 | [D] | [cover:076] | ‘Garage Door’ - Setting |
| 13:52:14 | [D] | [cover:086] | Command: CLOSE |
| 13:52:14 | [W] | [konnected.gdov2-s:039] | Garage door is already closed. Ignoring close action. |
| 13:52:14 | [D] | [cover:170] | ‘Garage Door’ - Publishing: |
| 13:52:14 | [D] | [cover:178] | State: CLOSED |
