GDO BlaQ Stopped Working With Hubitat
Also posted in the Hubitat community with HE log. Not sure what the issue is but all of a sudden both of my GDOs are no longer working with Hubitat. Both show online in HE and if I initialize it does change from connecting to online. They both show open in HE but are physically closed. None of the buttons, on/off open/close do anything. The web interface is working fine. I have tried rebuild the firmware on both. I have unplugged the GDOs and the Blaq as well as shutting down HE and left them all unplugged for 30 seconds. Not sure what else I should try.
Update: 7/30 - I have repaired the driver in hubitat package manager (You should add an additional note in the driver code showing which version it is) no change.
@nate I am doing some troubleshooting today and I beleive this may have started after I updated the firmware to V1.5.9.7. I switched to my backup hub and I am seeing Hubitat Home Hub C8 Pro(new)’ using outdated API 0.0, update to 1.14+ in the web interface logs. I thought I saw some yellow lines when I was lookig at the logs with my primary hub connected but because the logs were scrolling so fast I couldn’t read them. Sure would be nice to have a better way to see the logs.
Issue has been resolved. See Hubitat Community: [RELEASE] Konnected Garage Door Opener Official Driver
