GDO blaQ / Security 2.0+: Unknown Commands in logs
Received my blaQ and got it setup with ease. Everything seems to be working, though I’m seening the “Press Bar to configure” issue on my Wall Control Panel (I have this one) so I’ve ordered a replacement for that based on earlier threads.
I’ve also noticed a fair amount of “Unknown Commands” in the logs. I think this is from activity from the wall panel control, but I’m not positive. Some examples:
[11:29:03][V][esp-idf:000][gdo_main_task]: I (9151133) gdolib: cmd=09c (UNKNOWN) byte2=00 byte1=00 nibble=5
[11:29:03][V][esp-idf:000][gdo_main_task]: W (9151064) gdolib: Unhandled command: 48b (GET_OPENINGS)
[11:29:59][V][esp-idf:000][gdo_main_task]: W (9206898) gdolib: Unhandled command: 400 (PAIR_2)
[11:29:53][V][esp-idf:000][gdo_main_task]: W (9201535) gdolib: Unhandled command: 401 (PAIR_2_RESP)
[11:28:51][V][esp-idf:000][gdo_main_task]: W (9139574) gdolib: Unhandled command: 0a0 (PAIR_3)
[11:28:51][V][esp-idf:000][gdo_main_task]: W (9139690) gdolib: Unhandled command: 0a1 (PAIR_3_RESP)
[11:30:28][V][esp-idf:000][gdo_main_task]: W (9236753) gdolib: Unhandled command: 085 (OBST_2)
[11:28:50][V][esp-idf:000][gdo_main_task]: W (9138446) gdolib: Unhandled command: 080 (GET_STATUS)
[11:28:52][V][esp-idf:000][gdo_main_task]: W (9140391) gdolib: Unhandled command: 409 (UNKNOWN)
[11:29:03][V][esp-idf:000][gdo_main_task]: W (9151135) gdolib: Unhandled command: 09c (UNKNOWN)
Full logs here:
logs_konnected-612024_logs (1).txt (52.1 KB)
So far it doesn’t seem like these unhandled things are impacting the blaQ operation, but will report back if that changes.
The GDO blaQ taps into the proprietary Security+ protocols designed by Chamberlain and reverse-engineered by the open source software community and our own experimentation. There are some commands or communications that are still unknown and/or inconsequential to the typical operation of the blaQ. Maybe over time we’ll figure out what these mean, or maybe not. In any case, it’s nothing to be concerned about.
