I just installed 3 Blaq GDOs with lift master openers. They are about 12 years old with purple learn buttons and use LM889 remote openers and a myQ gateway. Two worked fine for 24 hrs but the third started getting flooded with random open close stop signals shortly after install. Mostly close and stop but it did open for 3-4 minutes as well. I unplugged it for the night and it stopped. In the morning I reflashed it and it seems stable for now. But last night the middle door also showed some random close and stop signals. I’ve read old threads on this that seemed to be a crash issue that was resolved. GDOs are not crashing or rebooting. Any thoughts?
Are you using our standard ESPHome firmware or the experimental Matter firmware?
ESP Home. I am only integrating with Control4 and no others and C4 is not yet connected. Could this be the issue?
Ah, I think I understand now. Those screenshots were from the myQ app…
Go into the internal web page of each GDO blaQ and set the Security+ protocol setting to Security+1.0 with smart panel. Because you’re using the 889LM, which is a digital/smart panel, this setting makes sure that the blaQ only listens to the existing smart panel and does not try to emulate one.
Thanks, It was already set to Security+1.0 with smart panel since install.
