GDO BLAq not working Liftmaster B2405T (yellow learn button)
First-time user trying to connect this to my garage door and operate through Smartthings. After hours of attempts finally got the wifi connected (72% signal) and firmware updated - thought that was the hard part! When I wired this up, the wall button went blank and the door wouldn’t operate, either via the button or Smartthings. Opener was flashing 1 up, 3 down on the adjustment buttons (or 3 down 1 up?). Tried wiring both ways - leaving wall button wires as is on the opener, and using the button connections on the Blaq device, with red/white Blaq wires connected per the diagram in both cases - neither method works. What am I missing?
1 UP, 3 Down means that there’ a short in the wall button wiring somewhere [source]. Double check your wiring. Red and white DO matter. Take a pic and post here if unsure.
