GDO Blaq light control vs mounted panel light toggle control
It was mentioned in this post.
nate Konnected Founder
May 2024
I’ve been doing a little research on the issue and found that LiftMaster has extended the warranty on the 888LM wall panel and will replace it with an 889LM via this form.
Good info on this forum thread.
I am working on sourcing this same combination of equipment so we can test against it.
