GDO blaQ 52a9b4 Random opening and cannot set to +1 and Wall
Set up worked fine with Purple button but would only work if set to Auto. Than about a week later Garage has opened randomly at 2:39 AM.
Read the updates and followed suggestions.
Tried to set “+1 and wallpanel” but then system is non functional. Switchback to auto and it works (defaults to Security+1),
Obviously do not want door to open randomly.
Also note that during installation the system seemed to work with dry contacts.
i.e. Door opened just by connecting red and white connectors.
Hi @scott_Sedman,
Can you please tell us what type of wall button you have connected to this opener? Also what is the firmware version (Konnected project version) on the Konnected device?
Yes, the purple-button openers do respond to a dry-contact trigger. The purple button indicates Security+1.0 protocol which also responds to a dry contact trigger.
Thanks for getting back. Control panel is 398LMC with lift master M3585CS 3/4 HP Garge opener.
Working with HA through ESPHome2025.3.2 and project version is 1.4.0.1
In addition to sporadic opening (infrequent) the HA logs show continuous updates for the following:
lights on/off,
Locked/unlocked
as well as obstruction detected/cleared.
These logs show up almost every 5 minutes.
Other items may not be related:
Garage opens/closes on switch command in HA but seems to have issues with Apple HomeKit Bridge integration. Open works (?) but close seems to have issues
Hi @scott_Sedman,
Unfortunately it’s the 398LMC that’s the problem. Unfortunately, this is the one (very old) wall button that just doesn’t work reliably with the GDO blaQ. There’s a post about it here and I’m working on re-organizing our knowledge base so this is easier to find.
I recommend replacing the wall button with the 889LM wall panel and then set the protocol setting on the GDO blaQ to Security+1.0 with smart panel
Figured as much. Really love your alarm products that work flawlessly. Guess I should have researched my garage model more before buying GDO Blq. I’m not quite ready to invest another couple of hundred on top of what I paid. Will look at disconnect until I am ready to upgrade the whole system.
@scott_Sedman a cheaper option is to replace the 398LM with a dumb wall button like this basic one or a 78LM generic. Both will work with a purple-button Security+1.0 opener to toggle open and closed, however the light and lock secondary buttons will not work when on the same circuit as the GDO blaQ.
Tksfor follow up and responding to my issues. Will look into options and advise any results.
Quick Update. Purchased the 78LM and installed. Seems to work and checking the logs not getting a lot of chatter between the Garage Opener and Home Assistant. So that is good. Opens and close works. Will work on some automations now and also ensure no un-triggered openings. Lock out seems to work but manual lights on/off not. But lights come on when garage opens and turn off automatically a couple of Minutes later .
So seems to be a reasonable fix. Tks again.
