We’re excited to announce the release of firmware v1.5.0 for the GDO blaQ (GDOv2-Q)!
This update brings some nice fixes and improvements that many of you have been waiting for.
Obstruction Detection Fix
A key issue affecting the obstruction sensor not reporting properly has been resolved. Your GDO blaQ will now correctly recognize and respond to obstructions to the IR safety beam within a few seconds.
Improved Partial Open (Percentage Control)
The feature that allows you to open the garage door to a specific percentage has been enhanced. It now works more reliably in both directions, making partial door openings smoother and more consistent regardless if the door is initially open or closed.
How to Update
You can get the latest firmware by updating via the Konnected app, or if you’re managing your own firmware config through ESPHome Builder, you can update automatically from ESPHome Builder. Source code and binaries are available on Konnected ESPHome GitHub release page.
Thank You
A huge thank you to our community for reporting issues and helping us improve the GDO blaQ experience. Keep the feedback coming—we’re listening and making updates regularly.
Basically after selecting upgrade the app (iOS) goes to a blank white screen with 3 dots on top. Looks like it wants to load something but never moves forward.
they where definitely registered, I’ve had these for a few months.
I don’t know why, but going back to settings moved things forward on two of them.
The 3rd left me with a new problem. One of them changed from a static IP to dynamic, but in Konnected App it still has the static address.
I tried adding the device (with the dynamic address) but it won’t add it.
How can I change the address?
Triggered the firmware update today and everything seemed to go alright. But not a happy gadget anymore. Went from v1.4.1 to v1.5.4.1 and while it shows that it’s connected to the network it will not respond to HA anymore nor will the app interact with it correctly. Going to go to the physical flashing instructions and fingers crossed I’ll have it working again. Will see if I can figure out why it borked like it and will report back if successful
A firmware update alone shouldn’t cause connection problems with Home Assistant.
What it could be is related to an encryption key used by the API. If you went from 1.4.1 to 1.5.4.1 that indicates that your original firmware was a “stock” build (it’s missing the 4th digit in the version number) and your updated firmware was built via our build service.
If you had set an encryption key previously, it could have been overwritten, changed, or removed because our build service manages encryption keys for you.
It wasn’t just Home Assistant, even though I could see the unit through my network monitor the webpage wasn’t pulling up for me. I flashed it this morning to 1.5.4.1 through the install website and everything is back to normal. During the app firmware update I had only set the SSID and password, not changed anything else from default. If I can find a pattern to recreate this (hopefully not) I’ll let you know.
