Garage door not opening or closing
I have a GDO White, my garage door does not open or close, it takes many try and eventually it close or open. I move the GDO little bit more away and move it closer and still getting same stuff, I ran the calibration as well
I have OverHead garage.
I notice if I move the calibracion setting up or down and try to open the door it works most of the time…not sure if that trigger something?
also notice the Sensor Distance is “NA”
Thanks.
11:04:03 [W] [konnected.gdov2-s:088]
Garage door transition timed out. Resetting state.
11:04:03 [D] [cover:156]
'Garage Door' - Publishing:
11:04:03 [D] [cover:164]
  State: CLOSED
11:04:03 [D] [cover:172]
  Current Operation: IDLE
11:04:04 [D] [vl53l0x:304]
'Sensor distance' - Distance is out of range, please move the target closer
11:04:06 [D] [vl53l0x:304]
11:04:09 [D] [vl53l0x:304]
11:04:11 [D] [vl53l0x:304]
11:04:14 [D] [vl53l0x:304]
11:04:16 [D] [vl53l0x:304]
11:04:17 [D] [esp32.preferences:149]
Writing 1 items: 1 cached, 0 written, 0 failed
Hi @KrOsS,
First, to clarify, the sensor distance of “NA” is completely normal when the garage door is closed and there is nothing in front of the GDO White’s sensor. The sensor can only see about 2m, so typically if the garage is empty and the GDO White is mounted on the ceiling, it will read “NA” whenever the garage is closed, and the state should read as closed.
When the garage is open you should see a reading within a few centimeters of the calibrated value, and the state should read as open.
The first thing is to check and make sure that the state is reporting correctly. If the state is incorrect, the open/close commands may not respond properly.
Also double-check that the wires are inserted correctly and secure.
Please send logs of the open/close actions if it’s still not working correctly.
hello @nate I check cables, even switch them to see if that makes any difference, sensor seems to be working as it can tell when door is Open or Close (not problem there), the calibration seems to work as well…everything seems to be working but it just works randomly or when it wants to or when I change something on portal.. if I put both cables together door close (as you show on video) so I know cable are secure from motor,
the question is why does it work randomly. maybe i’m the lucky one and got defective device? here are some logs while door is close
Not working Log
17:02:10 [D] [vl53l0x:304]
‘Sensor distance’ - Distance is out of range, please move the target closer
17:02:10 [D] [cover:080]
‘Garage Door’ - Setting
17:02:10 [D] [cover:090]
Command: OPEN
17:02:10 [D] [button:022]
‘garage_door_opener_button’ Pressed.
17:02:10 [D] [light:090]
‘blue_status_led’ Setting:
17:02:10 [D] [light:103]
State: ON
17:02:10 [D] [cover:156]
‘Garage Door’ - Publishing:
17:02:10 [D] [cover:164]
State: CLOSED
17:02:10 [D] [cover:172]
Current Operation: OPENING
State: CLOSED
17:02:11 [D] [light:090]
17:02:11 [D] [light:103]
State: OFF
17:02:13 [D] [vl53l0x:304]
17:02:15 [D] [vl53l0x:304]
17:02:18 [D] [vl53l0x:304]
17:02:20 [D] [vl53l0x:304]
17:02:23 [D] [vl53l0x:304]
17:02:25 [D] [vl53l0x:304]
17:02:28 [D] [vl53l0x:304]
17:02:30 [D] [vl53l0x:304]
17:02:33 [D] [vl53l0x:304]
17:02:35 [D] [vl53l0x:304]
17:02:38 [D] [vl53l0x:304]
17:02:40 [D] [vl53l0x:304]
17:02:43 [D] [vl53l0x:304]
17:02:45 [D] [vl53l0x:304]
17:02:47 [D] [esp32.preferences:149]
17:02:48 [D] [vl53l0x:304]
17:02:50 [D] [vl53l0x:304]
17:02:53 [D] [vl53l0x:304]
17:02:55 [D] [vl53l0x:304]
17:02:58 [D] [vl53l0x:304]
17:03:00 [D] [vl53l0x:304]
17:03:03 [D] [vl53l0x:304]
17:03:05 [D] [vl53l0x:304]
17:03:08 [D] [vl53l0x:304]
17:03:10 [D] [vl53l0x:304]
17:03:10 [W] [konnected.gdov2-s:088]
17:03:10 [D] [cover:156]
17:03:10 [D] [cover:164]
State: CLOSED
17:03:10 [D] [cover:172]
17:03:13 [D] [vl53l0x:304]
17:03:15 [D] [vl53l0x:304]
17:03:18 [D] [vl53l0x:304]
17:03:20 [D] [vl53l0x:304]
17:03:23 [D] [vl53l0x:304]
17:03:25 [D] [vl53l0x:304]
17:03:28 [D] [vl53l0x:304]
when finally decide to work
17:15:00 [D] [vl53l0x:304]
17:15:02 [D] [cover:080]
17:15:02 [D] [cover:090]
Command: OPEN
17:15:02 [D] [button:022]
17:15:02 [D] [light:090]
17:15:02 [D] [light:103]
State: ON
17:15:02 [D] [cover:156]
17:15:02 [D] [cover:164]
State: CLOSED
17:15:02 [D] [cover:172]
State: CLOSED
State: OFF
17:15:02 [D] [vl53l0x:304]
17:15:05 [D] [vl53l0x:304]
17:15:07 [D] [vl53l0x:304]
17:15:10 [D] [vl53l0x:304]
17:15:12 [D] [vl53l0x:304]
17:15:15 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.877 m
17:15:17 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.883 m
17:15:18 [D] [cover:156]
17:15:18 [D] [cover:162]
State: OPEN
17:15:18 [D] [cover:172]
17:15:18 [D] [binary_sensor:047]
‘garage_door_range_sensor’: ON
17:15:20 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.872 m
17:15:22 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.866 m
17:15:25 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.867 m
17:15:27 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.896 m
17:15:30 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.887 m
17:15:32 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.871 m
Try to close again but did not work
17:19:11 [D] [cover:080]
17:19:11 [D] [cover:090]
Command: CLOSE
17:19:11 [D] [button:022]
‘Pre-close Warning’ Pressed.
17:19:11 [D] [light:090]
‘warning_led’ Setting:
17:19:11 [D] [light:103]
State: ON
17:19:11 [D] [light:164]
Effect: ‘Strobe’
‘Play sound’ Pressed.
17:19:11 [D] [rtttl:062]
Playing song mission_imp
17:19:11 [D] [cover:156]
17:19:11 [D] [cover:162]
State: OPEN
17:19:11 [D] [cover:172]
Current Operation: CLOSING
17:19:11 [W] [light:022]
‘warning_led’: brightness not supported
17:19:12 [W] [light:022]
17:19:13 [D] [vl53l0x:310]
17:19:13 [W] [light:022]
17:19:14 [W] [light:022]
17:19:15 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.891 m
17:19:15 [W] [light:022]
17:19:15 [D] [rtttl:405]
Playback finished
17:19:16 [D] [rtttl:405]
Playback finished
17:19:16 [D] [light:090]
17:19:16 [D] [light:103]
State: OFF
17:19:16 [D] [light:164]
Effect: ‘None’
17:19:16 [D] [button:022]
State: ON
17:19:16 [D] [cover:156]
17:19:16 [D] [cover:162]
State: OPEN
17:19:16 [D] [cover:172]
17:19:16 [D] [script:090]
Script ‘garage_door_transition_timeout’ restarting (mode: restart)
State: OFF
17:19:18 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.888 m
17:19:20 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.893 m
17:19:58 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.885 m
17:20:00 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.874 m
17:20:03 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.876 m
17:20:05 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.884 m
17:20:08 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.878 m
17:20:10 [D] [vl53l0x:310]
17:20:13 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.882 m
17:20:15 [D] [vl53l0x:310]
17:20:16 [W] [konnected.gdov2-s:088]
17:20:16 [D] [cover:156]
17:20:16 [D] [cover:162]
State: OPEN
17:20:16 [D] [cover:172]
17:20:18 [D] [vl53l0x:310]
17:20:20 [D] [vl53l0x:310]
17:20:23 [D] [vl53l0x:310]
‘Sensor distance’ - Got distance 0.880 m
17:20:25 [D] [vl53l0x:310]
Hmm, it looks like the open/close detection is working fine.
Since you said that when you touch the wires together it works, try increasing close trigger duration. By default this is 300ms. Try increasing it to 500ms or 1s. This is the time that the wires are “touched” together by the internal mechanism when commanded to open or close. It may be that your garage opener needs a longer closure to respond reliably.
You can find this setting in the Konnected app > Settings > Garage Open/Close detection > Advanced > Trigger closure duration.
After changing the setting to 500ms that fix it! it opens every time! thank you!!! now I can close garage from work when wife leave the door open!
