I have all the wires connected sensors window doors ect. my problem is the siren and the beep beep in smartthings. the siren and the beep works ok when i turn it on however when i set the Alarm to away or stay it turns off dosen’t work
You need to set up the siren as a Response in SmartThings Home Monitor.
Home Monitor > Settings > Security > Set response
Thanks that worked fine. now i need a little help with the Beep Beep
