Factory Reset Pro
It is not clear from the instructions how to factory reset the Pro. It says to connect a jumper between zones 1 and 2 and reboot. I've tried and haven't gotten tit to work but I'm not sure if I'm doing it right.
Can anybody explain this better than these instructions? I plug the jumper into the top part above the screws for zone 1 and zone 2 (not ground). What does the other end plug into? Does it plug into anything? There should be picture examples of this at least.
Got it working. To factory reset, you take 1 wire and strip both ends and connect zone 1 to zone 2. power up, unplug the 2 wires and press reboot.
Nope, doesn’t work for me, just like this board.
