External Bell battery
I’ve managed to get the Texecom Odyssey 1e bell box installed and it now doesnt have the red light showing constant alarm state on the panel pro.
However what now happens is if i trigger the airen via the switch the sounder starts blaring away but when i toggle the switch again to turn it off it does nothing and continues to blare away.
Only way to stop it is to remove the power to it and let the BELLS own battery backup rundown.
Does anyone know if the battery is the problem?
Im suspecting that the alarm switches on pushing power through but then when the switch is turned to off the power is cut but its detecting it as a powercut of sorts and kicking the battery in to continue the alarm state? Would removing the battery let it function as on/off?
Would anyone have any idea? Im led to beleive that US sirens dont have battery backup so is prob mot an issue
James
