Ade Optima Compact External Siren and External Bell connection
Hi,
I have received my Konnected board and am happy with all the zone connections, however, as a user based in the UK, I've found the siren wiring confusing. I looked at the following page:
https://help.konnected.io/support/solutions/articles/32000026325-wiring-a-siren-uk-version
unfortunately this page does not have the correct labels for my setup. I have an Ade Optima Compact alarm and the external siren/bell connections are marked up as such:
T =Strobe- (manual says -ve tamper return)
A =Strobe+ (manual says -ve supply 0V)
D = Bell+ (manual says +ve supply 12V)
B=Bell- (manual says -ve sounder trigger)
Could someone with the same/similar panel in the UK or EU tell me which of the TADB connections should be connected to which of the Alarm/Aux connections on the Konnected board please? I don't want to try trial and error as I am worried I may damage something.
Thanks,
Steve.
I just realised the Strobe connection is additional/seperate to the TADB external sounder connections, the manual states:
Terminal 19 (marked as Strobe+ on the Ade alarm ) is +ve
Terminal 20 (marked as Strobe= on the Ade alarm) is switched -ve
I do not have a wire connected to the Strobe+ (terminal 19) only the Strobe- (terminal 20).
Prior to installing the Konnected board, both the external sounder/bell and external strobe both go off in an alarm condition and also for 20 minutes when their is a total loss of power (external bell/strobe must have a backup battery installed up there).
This is a pretty fun game, but requires players to have fast hand skills to choose the right arrow keys and at the right time they touch the arrow icons available on the screen to be considered valid. . If you have ever played Audition, you will get used to the Friday Night Funkin game very quickly.
I have exactly the same system.  Did you have any success?
I was never able to solve the problem.
I’m making the same migration but my install came with a handy “panel connections” table that instructs how to connect the bell box to various panels, including Optimas (that use Strobe and TADB) and Regents (that appear to use ABCDS). The upshot is that I think I have a mapping between the ADEs and the advice in the Konnected link:
Bell Box Optima Regent Konnected Support Konnected (Pro)
Trigger -ve B B ALARM - ALRM1 -
Supply +ve D A ALARM + 12V+
Supply -ve T C AUX -(?) AUX-(?)
Strobe +ve Strobe + A ALARM + 12V+
Strobe -ve Strobe - S ALARM - ALRM1 -
Tamper OUT A D AUX - AUX-
I guess the takeaway is that:
  1. The Supply terminals are connected to AUX (for continuous power).
  2. Strobe and Trigger (the latter in conjunction with #1) are simple switches that can be controlled by Konnected
  3. The Strobe and Trigger have separate terminals so that the strobe can be kept on after a trigger event. In this setup, they will be on and off together, although ALRM2 on the pro can be used to keep them separate.
  4. Tamper will be not function - although maybe it can be wired to a zone?
None of the above is tested yet.
I have successfully wired the bellbox as follows:
Supply +ve → 12V+
Supply -ve → AUX-
Trigger -ve → ALRM1 -
Strobe +ve → 12V+
Strobe -ve → ALRM2 -
The Tamper out required the use of an optoisolator to function correctly:
12V+ → opto in source
Tamper OUT → opto in sink
zone terminal → opto out source
zone ground → opto out sink
Hope that’s useful!
