Hey there,
I created a new automation in HA, the trigger is the scanning of a NFC tag, if the garage door is open it should close.
The automation works, but the garage door won’t close. I hear the beep but it won’t shut. If I use the buttons in HA the door closes as it should. Also the other way around, opening the garage if closed when scanning the tag, works perfectly.
I also have an automation with an NFC tag. My automation calls a script that toggles the door.
sequence:
- choose:
- conditions:
- condition: state
entity_id: cover.konnected_garage_door
state: closed
alias: Is closed
sequence:
- action: cover.open_cover
metadata: {}
data: {}
target:
alias: Open
- conditions:
- condition: state
state: open
alias: Is open
sequence:
- action: cover.close_cover
metadata: {}
data: {}
target:
alias: Close
alias: "Garage Door: Toggle cover"
description: ""
icon: mdi:garage
This works reliably for me for both opening and closing the door.
What does your automation look like?
I use this really basic automation:
alias: Tag Garage Door is Open
description: “”
triggers:
- trigger: tag
tag_id: e491afc8-35fd-462c-8695-31ad6f447712
conditions:
- condition: device
device_id: c1f7ab3436dcb794b0a1b20fdb8baaaf
domain: cover
entity_id: 6f71cf99338e0edbd567dcaf8ecb9c3f
type: is_open
actions:
metadata: {}
target:
entity_id: cover.konnected_52394c_garage_door
data: {}
mode: single
Try changing your condition to a state condition:
conditions:
- condition: state
state: open
I don’t think the state was the problem, since the automation worked, it just made the warning sounds before closing but never closed.
I used @drothenberger’s script, and so far it works like a charm!
