Main board I am interfacing with
GE - Caddx - NX8V2
2 Keypads control the system
Interlogix NX-148E-RF (with 2 line LCD panel), NX-1308 E (no LCD)
I got 12 zone pro panel interface kit. Started carefully. Now have 8 zone (pls note all zones on old panel NX8V2 are used, no free zone) connected to 2 interface board and then thru ribbons to Pro panel. Connected to Ethernet first, faced some issue so on Wifi now (reflashed to Ethernet, all good).
All 8 zones are now added to Smarthings and I can see in Smarthings app that they show correct status (door opening closing and motion). So far so good. But it came after 2 evenings of firmware updates (i guess I have done it 10 times or so) and changing few things.
Where I need help:
I had 3 wireless zones in my NX-148E-RF which I think cannot be programmed into Konnected and will always be in NX-148E-RF. If they get triggered then Konnected panel will know but will not know what triggered NX8V2. Pls confirm. Requesting Konnected team or users for help.
Now, I need to do this
Figure out where to connect wires on NX8V2 panel to know if it is armed or disarmed and if its triggered or not [this is explained for other brand panel at https://youtu.be/-zOMsLEMQgg?t=982 in one of Konnected videos but I need help on this with panel NX8V2 . Other end of wire(s) will connect to empty wired zone of one of the 2 interface boards I am using.
Add Keyswitch functionality thru relay on one of the alarm panel interfaces to arm/disarm remotely. For this I am assuming that I need to use one of the zones from NX8V2(and because I dont have any vacant zone on panel I will need to move one of the wired zones purely to Konnected Pro Panel). To do this, I will need to do programming in NX-148E-RF to remove the zone because wires from the zone which is disconnected will not be connected to traditional NX-148E-RF. Pls confirm? I think there needs to ve resistor in parallel on NX8V2 for Keyswitch to work. Any pic or help here is also appreciated.
Linking wiring diagram for NX8V2 so you can tell me where to connect wires to get info on armed-disarmed or triggered. Point 1 above.
See page 8 (at bottom of pages of linked pdf)
Once I am able to set my system, I can share complete process with video,pics,documentaiton on how to use interface kit with Caddx-GE-Networx system and how to make it work with Smarthings. I can fit it in 2 page documet and few pictures. Its litle tricky and there are some nuances due to lack of exact documentation (Tricky for customers because we dont work on security systems daily)
After many days of trial and error, reading documentation for Interlogix programming, NX-8V2 circuit board (components on board) I was able to fully set up Konnected Alarm Panel Pro 12-Zone Interface Kit alongwith existing NX-8V2 system. I will pusblish details in few days but I can say this
Konnected documentation is correct but incomplete
I tried to use support AI and human support. It was very difficult (I was unable to) to talk to anybody at Konnected. I was able to do email exchanges but some critical answers I got were wrong or incomplete. It was like me explaining everything in very detailed way and I got one liner incomplete responses. I am sorry if my expectation was high.
A very normal DIY person would have returned the panel but i wanted to make it work and took it as challenge and completed it (except connecting Siren which I think will work as its easy)
As I said earlier my experience directly relates to documentation and support. Product itself is great.
Documentation is pretty generic and misses out
Result is that after all is setup I see myself on build version 25 something. This is how many times I updated firmware.
If Konnected folks would like to connect I can share the issues, documentation and suggestions. Thank you.
Hi Parv, I am in a same situation. I have a 19 zone networx V8 panel which I am hoping to upgrade with 24 zone interface kit. Would you able to share you experience.
Hi, I have the same set up at my house, the NX8 with LCD screen key pad that is professionally monitored, and I bought the Pro Interface Kit, my goal is to have access to the sensors on my smart home platform and be able to monitor the system, arm and disarm and have tablets mounted in the house to arm and disarm. I am using Home Assistant as my smart home platform. I have not yet attempt to install the system. Do you have any suggestions? Nervous about starting. I want to be able to program an output on the keypad for arm/disarm. Need also to rig a panic trigger. Thanks for your help.
I am strongly considering purchasing the Konnected Alarm Panel Pro 12-Zone Interface Kit to interface with my NX-8V2, and subsequently with my OpenHAB system. I consider myself pretty technical, but if I can avoid the apparent hair-pulling that you had to endure to accomplish this, I would be very appreciative.
It sounds like you had trouble figuring out where to connect to get the alarm status? Were you eventually able to distinguish between armed away, armed stay, and disarmed?
Can you please document your successful set up? I used Smartthings. Can arm away and arm stay but could not disarm remotely. Can see zones open or close. Cannot see or be notified when alarm is tripped.
