I have the 6 zone interface kit and have the zones connected to my Networx NX-6v2. The zones report correctly via Home Assistant. The issue is that I haven’t figured out is how to get the relay to work to arm and disarm the alarm as well as reporting the alarm status (armed home, disarmed etc)
Zones 1-5 are a mix of windows and doors with wired sensors. Zone 6 is a wired glass break sensor. There are three keypads, all without LCDs.
Did you see this post on NX-V8 which should be similar?
I wrote up a tutorial on using the AUX outputs with Konnected and programming a keyswitch in Networx to use with Konnected relay for arm/disarm functionality
