blaQ obstruction sensor stuck in problem
I’ve had the blaQ installed and working just fine for a while now. A few days ago, possibly after updating ESPHome and recompiling the firmware, the Obstruction sensor got stuck on Problem.
I’ve tried rebooting the GDO, resyncing it, and have also reconnected the wires to the garage door. Nothing I do clears the obstruction problem.
To be clear, the garage door opens and closes fine, so the garage door is reading the sensors correctly. If I make an obstruction, the door will not close.
I’m using 2026.2.0 of the ESPHome firmware from GitHub - konnected-io/konnected-esphome: ESPHome firmware configuration and recipes for Konnected devices.
I am regularly seeing obstruction problem and then obstruction cleared messages
I power-cycled my garage door opener then the blaQ, and that resolved the issue with the stuck obstruction sensor.
